Salut.Vedeti ca aveti o problema la server,cred...Cand incerc sa ma conectez se incarca putin dupa care se deconecteaza imediat.In consola apare doar atat:
O problema
ionas
, Dec 05 2013 04:21 PM
Posted 05 December 2013 - 04:21 PM
NET Ports: server 27015, client 27005
Server IP address 192.168.1.3:27015
Connecting to 89.44.246.57:27015 ...
Connection accepted by 89.44.246.57:27015
* Privileges set
Posted 05 December 2013 - 07:07 PM
De fapt nu e o problema in sine.
Avem doua clase de IP-uri banate din cauza a doi pustani care n-au ce face si intra cu hack-uri.
Daca totusi ti se mai intampla da 2-3 reseturi la conexiune si te va muta pe alt IP-uri si vei putea juca linistit.
LE: Vom verifica in orice caz sa nu fie si altceva. Mersi de tip
Edited by VerKoder, 05 December 2013 - 07:07 PM.
Posted 05 December 2013 - 07:14 PM
Posted 05 December 2013 - 07:58 PM
Da, clasele banate sunt 79.118.* si 92.81.*.
Chiar si asa ar trebui sa ti se schimbe IP-ul.
Imi pare rau pentru problema asta dar natura situatiei a impus masura asta.
Posted 06 December 2013 - 01:13 AM
Posted 07 December 2013 - 10:43 PM
Posted 07 December 2013 - 10:58 PM
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
